Up to 20% off select tools
Repair guides and support for the OnePlus 5T, an Android smartphone with a 6.01" AMOLED display. Released in November 2017. Successor to the OnePlus 5. Model number: A5010.
Is my display broken?
I’ve accidentally drop off my oneplus 5T then the screen imagen stop working but the touch response still works.
I’ve never opened it.
This would be something like disconnected display or maybe the display is broken and need replacement?
Everything else is working except for the screen image.
Add a comment
1 Answer
Most Helpful Answer
@javieresp from your description it sounds like a bad screen. I’d go ahead and replace it. While you open your phone you will have to check all the cable connection anyway so the work will be identical.
OnePlus 5T AMOLED Screen & Digitizer Replacement
Score 2
1 Comment:
Thanks! i'll try checking the connection, if not i'll buy a new display.
by Share
Add a comment
Add your answer
Jerohhdez will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 5
Past 30 Days: 13
All Time: 290
