Laptop will not power on
I replace the screen and everything was working fine. I noticed the track pad was a little sticky so I powered down and had to remove the internal battery to fix the track pad. Once I reassembled everything it is totally dead. No lights even when the charger is connected. I have taken it back apart and check for any loose connections. I have removed and reseated the RAM. I have tried to run off of ac power only with the battery removed but it is still completely dead. I have also tried a har reset with the battery out pressing the power button for 60 seconds and then going back and trying it all again.
Add a comment
1 Answer
Chosen Solution
Hi Justin,
All I can suggest is reviewing your assembling. Check that all cables are correctly oriented. What else could it be. Please,you did disconnect the battery before doing anything, right?
Service manual:
https://support.hp.com/nz-en/product/hp-...
Good luck.
Mike
Score 1
Add a comment
Add your answer
Justin Sousa will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 5
Past 30 Days: 12
All Time: 387
