A productivity focused laptop with a 15.6" screen from Lenovo, manufactured in 2016. The P500 model marker is located on the bottom left of the LCD bezel.
How to replace battery in ideapad p500
Add a comment
1 Answer
Chosen Solution
Hi,
Here’s the hardware maintenance manual for the laptop, taken from this webpage.
Go to p.44 to view the necessary pre-requisite steps and then the procedure to remove / replace the battery.
On p.91 Item #4 you will find the part numbers for the batteries. Search online using the appropriate part number only in the search box of your browser to find suppliers of the part. Usually the part number can be found on the battery itself if you wish to verify which one it is.
Score 1
Add a comment
Add your answer
joe will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 5
Past 30 Days: 27
All Time: 1,575
