Up to 20% off select tools
The Zoom H6 Handy Recorder is a portable audio recorder with interchangeable mics and several built-in effects, and can also be used as an audio interface for computers and tablets.
How I fix SD Reader or replace it?
I put in a SD card to the reader but it could not put out it, so I put it by force!
Now the readers Iron strings are up and the reader can't read!
Score 1
3 Comments
The proplem is here on this mudule
by Share
[image|2265134]
I can't but the sd card anymore!
by Share
i too got a stuck sd card after forcing it out the card lock broke, is the cardholder replaceable. thanks for any advice
by Share
Add a comment
1 Answer
Chosen Solution
https://d3nevzfk7ii3be.cloudfront.net/ig... looking at the teardown, it’s soldered. take it to a repair shop if you find a part, should be an easy soldering
Score 1
2 Comments:
Excuse me but the proplem is not here..
İts in SD reader mudule
by Share
I know. The picture is the closest I can get to it!
by Share
Add a comment
Add your answer
Anas Alathwary will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 29
All Time: 1,178
