Installing MAC X OS
I have Formatted the Original HDD of the MAC A1150 using the DiskUtility of another MAC so that the Formatting Type is compatible….
I have created a Bootable USB with El Capitan Using command Line by the following command.
sudo /Applications/Install\ OS\ X\ El\ Capitan.app/Contents/Resources/createinstallmedia --volume /Volumes/TOSHIBA--applicationpath /Applications/Install\ OS\ X\ El\ Capitan.app
The CLi successfully formatted the USB and installed the Installation media for El Capitan enabling the USB to be a Bootable Device… However, When I insert the USB into the MAC > Power up the Mac whilst holding Option And then selecting onto the Bootable Device I am getting presented with……..
A FOLDER WITH A QUESTION MARK INSIDE !! Any ideas to why or how I can resolve?
Add a comment
Most Helpful Answer
You’re trying to install OS X 10.11 “El Capitan”, but assuming you put the correct model in (15-Inch MacBook Pro from 2006), the latest version compatible with that model is Mac OS X 10.6 “Snow Leopard”. I could be mistaken, but I’m guessing the reason you’re seeing that symbol is because El Capitan isn’t compatible with that machine.
Score 1
Add a comment
Mac A1150 can not install from external drive has to be internal drive/ dvd drive only!
Add a comment
Add your answer
Fire Base will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 16
All Time: 1,169
