An i7 gaming laptop released in September 2017. Created to fight heat and keep air flowing with thermal engineering systems.
Mon ordinateur émet des BIP
Bonjour,
Mon ordinateur portable emet un bip mais ce n’est pas tous le temps (Legion Y520 )
J’ai changé la RAM , Les Disques dur sont OK (verifiés avec un logiciel) , j’ai vidé les condensateur avec la manip qui consiste a rester appuyé sur le bouton demarrage plus de 1 min .
Merci pour votre aide
—————————————————-UK version ———————————————————
Hello,
My laptop beeps but not all the time (Legion Y520 )
I have changed the RAM, the hard disks are OK (checked with a software), I have emptied the capacitors with the manipulation which consists in remaining pressed on the start button more than 1 min.
Thank you for your help.
Add a comment
1 Answer
Most Helpful Answer
Hi,
When it beeps, how many beeps and is there a pattern to the beeps?
Does the laptop stop booting when it beeps?
Does the laptop work OK sometimes? If it does, try performing a diagnostics test on all the hardware to see if it shows anything.
Score 2
Add a comment
Add your answer
s.defigueiredo will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 15
All Time: 340
