iRobot's Roomba 980 automated vacuum cleaner. Released on September 2015.
Keeps throwing a code 2 to empty trash
Keeps saying to empty trash but there is no trash in it
Add a comment
1 Answer
Chosen Solution
Error 2 on an iRobot Roomba 980 usually means that the rubber brushes are clogged and need to be cleaned. The most likely cause is hair stuck on the brushes, which is preventing them from spinning properly.
To fix the error, you can try these steps:
  1. Clear the brushes
  2. Pull the extractors out, clean any debris/hair on the ends, and pull the yellow end caps off
  3. Press the CLEAN button to restart
If the Side Brush is not spinning after cleaning, you may need a replacement Side Brush Module.
Score 1
Add a comment
Add your answer
Strain will be eternally grateful.
Past 24 Hours: 4
Past 7 Days: 6
Past 30 Days: 26
All Time: 355
