Released February 2012, identified by model number BP220.
dv582h movie format help
I got an LG dv582h from a garage sale and I came home discovering it has a broken disc drive, so I’m trying to load movies onto a USB flash drive, but I can’t figure out the dumb formatting of it, I tried using the divx converter program on my laptop but every time i try the program just closes, even if I reinstall the program, the only movie I got working is San Andreas (avi file) yet all my other files no matter if they are avi or mp4 or whatever I can’t get it to work, and the LG website doesn’t give me ALL of the video info that works (like fps, resolution etcetera,) may I ask for the full info so I know what to change in all my movies
if you want to try converting it yourself i’d be happy to send you the files.
please help me out as this is literately driving me insane to the point where i’m about to put a hammer through it if i don’t make any progress
Thanks!
Add a comment
1 Answer
Most Helpful Answer
Hi @theandroidkid ,
It may be better to find out why the DivX program closes in the computer first.
According to the user manual:
USB operation
Music files (MP3/WMA), photo files (JPEG) and DivX files can be played.
This unit is not supported when the total number of files is more than 600.
Bit rate: within 8 to 320 kbps (MP3), within 32 to 192 kbps (WMA),less than 4 Mbps (DivX file)
The USB function of this unit does not support all kinds of USB devices.
DivX file requirement
DivX file compatibility with this player is limited as follows:
Available resolution size: 720 x 576 (W x H) pixel.
The file names of DivX and subtitle are limited to 45 characters.
DivX file extensions: “.avi”, “.mpg”, “.mpeg”
Playable DivX subtitle: SubRip (.srt / .txt), SAMI (.smi), SubStation Alpha (.ssa/.txt), MicroDVD (.sub/.txt), SubViewer 2.0 (.sub/.txt),TMPlayer (.txt), DVD Subtitle System (.txt)
Playable Codec format: “DIVX3.xx”, “DIVX4.xx”, “DIVX5.xx”, “MP43”, “3IVX”
Only the playback function is supported with DivX 6.0 in the unit.
Playable Audio format: “Dolby Digital”, “DTS”, “PCM”, “MP3”, “WMA”
Sampling frequency: within 8 to 48 kHz (MP3), within 32 to 48 kHz (WMA)
CD-R/RW, DVD±R/RW Format: ISO 9660
Maximum Files/Folders: Less than 600 (total number of files and folder
Score 1
Add a comment
Add your answer
Bryn Trainor will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 10
All Time: 349
