Up to 20% off select tools
The Canon Powershot A590 IS is an 8 megapixel digital point-and-shoot camera with a 4x optical zoom and a 2.5 inch LCD screen.
SD Memory Card maximum
What is the maximum size SD memory card the Canon PowerShot A580 IS will accept?
Add a comment
1 Answer
Chosen Solution
According to the User Manual your camera accepts SD memory card/SDHC memory card/MMC Card/MMCplus card/HC MMC plus card. This means you could probably use a 32GB card. I do believe that most people do not go higher than 8GB to prevent read/write errors and buffer overflow etc.
Score 3
2 Comments:
My 590 is keeps saying memory card error and won't do anythinng what is the problem?
by Share
Hi brianshackelford607,
Have you tried a different SD Card?
Try using a card reader connected to a PC to verify if your SD Card is still OK or if there is a problem with the camera
by Share
Add a comment
Add your answer
good2go7 will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 7
Past 30 Days: 26
All Time: 4,698
