The Ninja Mega Kitchen System BL770 is a complete kitchen appliance manufactured by SharkNinja.
Replacing broken plastic gears
Our Ninja BL700 stopped spinning. I disassebled the unit and the plastic 3 gear unit at the top had shredded teeth not allowing the unit to spin. Ninja does not offer a replacement part but saud I can purchase a replacement base. Does anyone know where I can purchase the part. An internet search has not been fruitful. Thank you.
Score 1
1 Comment:
The person that answered your question isn't DIY savvy. You tore your unit down to find the 3 gear cluster inside the white casing. Apparently this is the main failure in the Ninja brand. I'm also trying to find a replacement, but you're the closest I've come to finding anything online.
by
Add a comment
1 Answer
If you are talking about the gear-looking part on the drive shaft that meets with the bottom of the blade assembly, it is called a coupler or coupling. I haven't found one for Ninja, but there are a lot for kitchen aid and waring around. I would wonder if one of these is 'compatible'.
Example: https://www.ereplacementparts.com/coupli...
Update (10/17/2020)
Similar question: The flexable rubber coupler has broken..
In that, this guide is referenced which includes a rebuild of the planetary gear assembly. I see now this is what you really needed
https://sites.google.com/site/dgeake51/h...
3 Comments:
No. It is the gear unit that turns the coupler.
by
Broken 3 gear unit that turns the coupler.
by
Add a comment
Add your answer
Tim Strickland will be eternally grateful.
Past 24 Hours: 2
Past 7 Days: 16
Past 30 Days: 74
All Time: 2,416
