How to replace system board?
How does one remove a current system board (mother board) and install a new one?
Hi,
Here’s the hardware maintenance manual for the laptop. Go to p.45 to view the necessary pre-requisite steps and then on p.47 the procedure to remove the systemboard. Reverse the procedure and necessary pre-requisite steps to install the new board
On p.69 Item #4 you will find the systemboard part numbers for all the systemboards suitable for the model. (check against the Yoga 710-15ISK column as some are for a Yoga 710-14ISK only). If you search online using the part number only you’ll get results for suppliers.
Past 24 Hours: 0
Past 7 Days: 5
Past 30 Days: 19
All Time: 363
