Why is my laptop blinking power button
my lenovo T450 is blinking the power button as soon as i plugin the charger and won't power on, it does all this when the power button is not pressed please help....
This usually happens due to a low voltage on the CMOS battery with many of these laptops - some do not care as MUCH like my E6440 because the Flash ROM and CMOS RAM are power sipping, while others like the E7440 are so sensitive even being .1v below what the board likes may cause an issue and the machine decides to stop booting. With a lot of these weird laptops having different low voltage response tolerances, it is a wildcard situation I tend to tread with caution around unless I know the machine can handle it first hand. An example of this is if I have a laptop with a overly sensitive board like the E7440. As an example, if the A00 board that has issues with batteries at 2.4V (early machines only), while the A01 board can handle it at 2.4V but has a POST error about a low CMOS battery (later production). That tolerance fix may come as a result of a BIOS update, or a hardware revision - usually with HW revisions batteries tend to be cheaper and more accessible then the replacement board which is truly “revised”.
In this case, your best bet to cure this permanently is a new CMOS battery - but for testing the method @oldturkey03 mentioned is best. If you can check it with a multimeter and make sure it’s within 3-2.5V, then I would do it but if not I would probably just replace it just to be safe at that point - especially an older laptop like this. The Lenovo Part# appears to be 04W1642 or 02K7078. If you look at the Lenovo HMM on Page 34, it shows HOW to test the battery as well. Once you have the bottom off, replacement is easy enough you can do it in 20 minutes tops - plus batteries are easy enough to replace it’s usually not worth replacing the board if a revision fixes the issue of CMOS battery sensitivity.
Tested solutions and all is working well. The CMOS battery was replaced and machine boots perfectly. Thanks community. Phillip from South Africa.
Hi everbody
I append a message here, because I have same issue, however nothing helped so far.
Unplugged battery, CMOS battery (3.2V measured), pressed power button 60 secs.
I still see the 3* blinks on power button and it doesn't start.
Any help would be useful.
Thank you very much
Same problem
Forbes Kay apparently the T450 has some issues with the CMOS etc. For some a quick fix that seems to work is to reset the CMOS. Just disconnect it from the motherboard, wait a couple seconds, then plug it back in. Check to see that if you remove your external battery and disconnect the internal battery that your laptop functions normally with the AC power supply adapter. Download the hardware maintenance manual from here and check page 48 etc.
Hi everbody
Also pressed the reset button on the bottom/back home.
Update: repeated all steps once again, pressed keyb Win+Ctrl+Shift+B ...then Power Button reacted positively, I hear beeps 1-3-3-3 (nothing was plugged back yet).
After plugging back in CMOS and memory, it started. I hope it will last.
Thank you very much
Past 24 Hours: 3
Past 7 Days: 39
Past 30 Days: 212
All Time: 24,693
6 Comments
Have you tried taking the battery out and just use the charger?
by mike
I tried a lot of things including that
by FORBES KAY
I'm sorry if this is a bit late; but, this issue could be caused by multiple reasons. Have you tried replacing the hard drive? The hard drive most likely might have failed.
Servicing manual (to see how to replace hard drive): https://download.lenovo.com/pccbbs/mobil...
Recommended hard drive replacement: https://amzn.to/3hBKGcx (or search up and buy "2.5 Inch SATA Internal SSD" or "2.5 inch SATA internal hdd")
Install Windows 10 on your hard drive after the replacement: https://youtu.be/rl6SeLSyztw?t=157 (or look at the servicing manual)
Just curious, are you still here?
by Anonymous Goose
BTW, the blinking power button means it recognizes you plugged in your charger.
by Anonymous Goose
I'm also struggling with the same problem, even after removing my battery it is still blinking on and off (..and the charger is not plugged in), I don't understand how...
by Siyabonga Mokoena
Show 1 more comment
