Guides for the Wi-Fi version of the iPad Mini 3 (A1599). Announced on October 16, 2014, the iPad Mini 3 is the successor to the iPad Mini Retina (now known as the iPad mini 2).
Is this ipad mini 3 charging okay?
Ive just bought an ipad mini to repair. Previous owner said “item has smashed screen. It was working but then froze and wouldnt turn off. Battery finally ran down and turned off. It charged again, but now wont charge or turn on”. So i know it obviously needs a new digitiser, and possibly a new LCD. Ive just put it on charge and its showing 5.17 V, and Amps are between 0.64 - 0.84. Does this indicate a faulty charging port, battery or something else?. Im new to repairing the ipads so any help would be gratefully received. Regards, Gary.
Add a comment
1 Answer
Well, it depends. Is it a 1.0A charger?
Does the charger get ridiculously warm when charging?
Could also be a damaged PMIC or bad wiring traces.
2 Comments:
Its a proper ipad charger and only gets normal warm.
by
It also doesn't connect to itunes. Not sure if thats because the battery is flat.
by
Add a comment
Add your answer
Gary Davies will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 19
All Time: 226
