Screen replacement for iPhone SE 2020
I have read that the screen on the iPhone SE 2020 is the same as the iPhone 8. Is this true? Can I replace a iPhone SE 2020 screen with an iPhone 8 replacement screen? Thanks.
Yes, you can replace the iPhone SE 2020 screen assembly with an iPhone 8’s.
Thank you for your help
Yep! A iPhone 8 screen works perfectly when installed in a iPhone SE 2020, and vice versa. Additionally, after a screen swap, you can follow the same procedure using a iCopy to transfer the serial number from the old screen to restore TrueTone functionality just like with the iPhone 8.
So, the only parts in the iPhone SE 2020 that are NOT compatible with the iPhone 8 are:
As soon as parts are available for the iPhone SE 2020, I’m tempted to buy a logic board, battery, and camera and install them in my old iPhone 8 to make a sort of “franken-phone”.
Anyways, hope that answered your question.
That’s actually wrong, it was reported initially that the camera is not interchangeable due to a YouTube video that came out a few weeks ago. It was actually lazy reporting because the YouTube video showed an iPhone 8 motherboard being put into an iPhone SE and then subsequently, the native cameras failed to work on the SE. But you can swap the camera module from an iPhone 8 or SE into the other and it will work. iFixit and another source have proven that an iPhone 8 camera will work in the new SE and the SE camera will work in the 8. There is still some question about if the iPhone SE sensor is truly the same as the 8, the modules are the same size so it’s assumed to be the same sensor but I don’t know if anyone outside of Apple really truly knows.
But he was not asking about the motherboard ,we asking about the screen
Yes , also same :
front camera
charger flex
volumen flex
back camera
display
vibrator engine
ear speaker
buzzer
all are the same
hola from Valencia Spain
Yes, but the SE does not have 3D Touch so it’s advisable not to use the SE display in an iPhone 8, but it’s okay to use the iPhone 8 screen in a SE.
Everything else except the battery is directly interchangeable.
https://www.youtube.com/watch?v=xBNdm0XB... 他们是一样的模组 可以交替并正常工作在两款设备中 包括连接方式以及前置模块
They are the same module, which can alternate and work normally in two devices, including the connection method and the front module
The two components that are not common in the new SE are the rear camera and the battery. Apple uses an 11 battery interface on the SE
That video doesn’t even show the swapping of camera modules, what it actually shows is putting an iPhone 8 screen on an SE phone body and putting an iPhone 8 logic board inside of an SE body and that causes the cameras on the SE not to work. But just swapping the camera module from one to the other DOES work.
iPhone SE camera in an iPhone 8:
iPhone 8 camera in an SE
can you change the iphone 8 back glass for a iphone se 2020?
Does 3D Touch works on the SE if an iPhone 8 screen is used?
Hello, but can you replace just the screen Glas on the iPhone SE?
Past 24 Hours: 3
Past 7 Days: 8
Past 30 Days: 28
All Time: 2,284
1 Comment
Thank you for your time. I really appreciate it.
by Isaac Strickland
