The digital camera was released by Panasonic in July of 2016. The Panasonic Lumix DMC-ZS60 has 18-megapixels and wifi mobile device connectivity.
Popping/Cracking Noise when zooming
When the camera is powered on, the lens makes a small cracking noise while extending. Other than that it works normally. How can I fix this?
Thank You!
Add a comment
1 Answer
Andrew Jensen  sounds like you may have some dirt/debris in there. Other than disassembling the lens and trying to clean it, which is a challenge without proper manual, there really is not anything you can do to fix it. Only other thing is to replace the lens Panasonic Lumix DMC-ZS60 Camera Lens Replacement
Add a comment
Add your answer
Andrew Jensen will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 7
Past 30 Days: 44
All Time: 1,160
