Repair guides and troubleshooting for HP Pavilion dv7 laptops, manufactured by Hewlett-Packard starting in 2008, and featuring a 17.3" diagonal display.
fv 274 av dc jack
I have a dv 7 fv 274 av and think it may be the problem and want to make sure not to get the wrong part . When plugged in if I play around I can get a light showing it is on and charging, the slightest movement and the light goes out. If I try to power it up the light goes out, When I don’t touch it and the light goes on the battery charge but not completely. Somehow the os is now corrupted and I can not get the computer to stay on long enough to do a repair of the system. My thought was a correct replacement of the jack might lead to be able to use the machine again.
Add a comment
1 Answer
Most Helpful Answer
murohyg27 this sentence in your description “When plugged in if I play around I can get a light showing it is on and charging, the slightest movement and the light goes out. If I try to power it up the light goes out “ would lead me to changing the DC in jack first. This video should be pretty similar to your system. Of course, you can download the service manual from here
Score 1
Add a comment
Add your answer
murphyg27 will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 5
Past 30 Days: 12
All Time: 255
