Released April 2015, also known by model name A10-70F ( 'F' representing that this is a wifi only model).
How can I fix my charging port?
Everything on my Lenovo tab A2 10 works except the charging port. When I plug in any charger it won’t charge the tablet. When my tablet lost its final charge I couldn’t use it anymore. I know its not the battery because it worked just fine its just charging the tablet was getting progressively harder and I had to angle my chargers in different ways so it could start charging the tablet.
Score 1
1 Comment
Where did you buy replacement charging port ? I saw some generic ones on Ebay.
by
Add a comment
1 Answer
Most Helpful Answer
@sal10 sounds like a bad charging port. It is soldered to the motherboard. Use this guide Lenovo Tab 2 A10-70 Motherboard Replacement to get there. Then you need to remove the old port and solder a new one in. This video has some pretty good directions. The ports are available at places like this
Score 4
4 Comments:
Not helpful, since the motherboard costs more than the tablet did brand new. It would be helpful if you included instructions on how to replace just the usb socket.
by
@steveclose72539 nobody said to replace the motherboard. The links referring to a how-to video as well as the replacement part. So, not a very helpful comment.
by
@oldturkey03 The instructions show how to remove and replace the motherboard. That doesn't tell me how to fix the broken charge port, which is what the OP asked for.
by
@steveclose72539 did you check the other links? The iguide shows how to remove the board "to get there. Then you need to remove the old port and solder a new one in" as show in the video. Now you can reinstall the board according to the guide.
Well neither here nor there. I am so sorry my answer did not meet your expectation. I'll try to be more explicit the next time.
by
Add a comment
Add your answer
Salvador will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 35
All Time: 2,373
