Akaso EK7000 is a 4K Ultra HD action camera. The camera was released in January 2017. The camera comes with built-in WiFi and can be remote controlled.
Half of Screen messed up
I have had the akaso ek7000 4k ultra hd since christmas 2019 and it is having a problem now. When i turn it on half of the screen is like blue transparent. What could be causing this?
Add a comment
Tyler Sawyer could be a bad screen or a bad connector. You do want to see if you can reseat the connector, making sure all the pins are clean and straight etc. If those are correct, try a new screen.
Add a comment
Just be aware too … the drivers for the screen are part of the firmware, so you can't use just any LCD screen (if you are replacing a broke screen)
if you update the firmware - with the wrong version, this will also cause problems - since the driver won’t match
  • more bad news …. the 4k is fake, so is the picture resolution
Add a comment
Add your answer
Tyler Sawyer will be eternally grateful.
Past 24 Hours: 2
Past 7 Days: 13
Past 30 Days: 35
All Time: 485
