Up to 20% off select tools
Model US998U. Can be identified by rear fingerprint sensor/lock button, 128GB storage, and wide-angle dual rear cameras. Released October 2017.
Incoming Call Screen Duplicate
My incoming call screen shows then a second later another one pops that I can't access. Cleared permission on all apps and that helped for a few hours but it came back.
2 Comments
Hi,
Is it always from the same number?
by Share
No all numbers
by Share
Add a comment
1 Answer
Chosen Solution
Hi,
Try wiping the cache partition and check if that resolves the problem.
If still no good, try using the phone in safe mode and check if the problem is still there.
If not, then a downloaded app is the cause of the problem. You will need to uninstall each downloaded app, one by one and test the phone in normal mode, between each uninstall to see if the phone works OK. When it does the last downloaded app that was uninstalled was the culprit.
Score 1
1 Comment:
Thanks seems robokiller was the problem
by Share
Add a comment
Add your answer
monte mason will be eternally grateful.
Past 24 Hours: 2
Past 7 Days: 3
Past 30 Days: 19
All Time: 397
