The HP Officejet 4620 is an all-in-one color printer, meaning it can print, scan, copy, and fax.
How to replace spring tentioner s HP 4620
How do I replace spring tentioner s on the back inside of my HP 4620 printer
Add a comment
1 Answer
This answer was originally to another question.
Hi,
Not sure which springs you’re referring to, but here’s a teardown video of the printer.
At 2:58 minutes into the video the two printhead tension springs are seen being removed by using a tool with a hook
At 7:36 minutes, one carriage unit spring clip is being removed. There may be one on the other end of the carriage.
At 11.57 minutes the feed roller spring is shown.
Hopefully this will help you to replace the springs.
Add a comment
Add your answer
Michelle Speegle Hayes will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 6
Past 30 Days: 32
All Time: 385
