Model A1237 or A1304 / 1.6, 1.8, 1.86, or 2.13 GHz Core 2 Duo processor
Not powering on with charged battery
MacBook air 2008 not turning on on battery power but turns on with charger cable battery indicator shows fully charged, have done smc reset no change. Powers on and off on charge cable, remove cable dies instantly.
Update (08/06/2020)
Could not run coconut battery on lion so tried this one not sure how accurate it is.
1 Comment:
Lets get a better idea on things here' Install this gem of an app! CoconutBattery take a snapshot of the apps main window and post it here for us to see Adding images to an existing question.
by
Add a comment
1 Answer
Wow! A battery thats gotten to 5911 cycles!
I think you really need a new battery! A batteries lifespan is about 1000, I think you pushed it a bit ;-}
Determine battery cycle count for Mac notebooks
Here’s the needed part MacBook Air (Original-Mid 2009) Battery and here’s the guide to put it in MacBook Air Models A1237 and A1304 Battery Replacement
Replace the 4200 mAh battery compatible with MacBook Air (Original-Mid 2009). 31 Watt Hours (Wh), 7.4 Volts (V). Image
Product
$29.99
1 Comment:
Ha yes I don't think that was quite right I'm just going to order a new battery and see what happens.
by
Add a comment
Add your answer
Aaron S will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 3
Past 30 Days: 16
All Time: 269
