My phone is not starting
my phone got wet 6 months before and was not starting i have taken it to repairers but they couldn,t start it now how can i fix it on my own at home
Hi
Water and electronics and electricity are not a good mix.
The impurities in the water causes corrosion and provides circuit paths for the electricity which were not in the phone’s operating design and could damage the components. The corrosion start immediately and is ongoing until it has been properly cleaned away.
First do not try to charge or to turn on your phone and then remove the battery as soon as possible to prevent any further damage. Even if the phone is off, there is still power available at various points on the systemboard. The phone’s power on/off button is not a power isolating switch. Think of the phone as being in an extremely low power state when it is off rather than being off and disconnected from any power source.
Then you need to disassemble the rest of the phone and clean all the affected parts using Isopropyl Alcohol 99%+ (available from electronics parts stores) to remove all traces of corrosion and water. Do not use "rubbing alcohol" as in some cases this is <70% IPA, can contain additives and is not as effective. If you do have to use it, check the label to verify the amount of IPA. The higher the concentration (%) of IPA the better.
Here is a link that describes the process. Electronics Water Damage
As always with electronics, especially surface mounted pcb be gentle when handling and especially when brushing away the corrosion. You do not want to remove any components from the boards. You will also have to remove any shields that may be covering some components as the water may have got in under them as well. Also disconnect any flex cables and clean the ends of the cable as well as the connectors that they were plugged into.
Hopefully after you have done all this the phone might possibly work correctly again.
After 6 months it may be doubtful but you can only try. Also you may have to replace the battery as well as it may have become depleted beyond recovery.
Here’s a video that may be of some help as it shows how to open the phone so that access to the internal components is possible.
Past 24 Hours: 1
Past 7 Days: 9
Past 30 Days: 49
All Time: 356
2 Comments
আমার ফোন অটো চালু হচ্ছে বন্ধ হচ্ছে
by Md Abdullah
by Md Abdullah
