A highly popular bike series produced by Yamaha from 1987-1995 including the Genesis and Exup models.
Why will the bike not start?
this is a 1987 fzr 1000.It won’t start.the starter works and engine spins but it won’t fire up.there is plenty of gas.
Score 3
2 Comments
Have you checked your spark plugs?
by
Please bike not Star
by
Add a comment
1 Answer
Most Helpful Answer
I would start by spraying a little bit of starting fluid in the air intake.
Try starting the bike after spraying the starter fluid.
-If the bike starts up and then dies, then you have to check the fuel filter, clean the carburetors, and check for clogged fuel lines
-If the bike cranks over without signs of starting at all then you might have an electrical problem with your ignition system. I would check the coils on the spark plugs and the spark plugs themselves.
Good luck
Score 1
Add a comment
Add your answer
zafar78600 will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 6
Past 30 Days: 44
All Time: 1,820
