Released September 20, Apple's mainstream 2019 iPhone comes with a 6.1" LCD touchscreen, dual cameras, and six available colors. Successor to the iPhone XR.
No service on my iPhone
I recenty bought an almost unused iPhone 11 that had a screen issue. I changed the screen myself and everything seemed to work workperfectly when I assembled it together.
The only issue i’m having is that my iPhone keeps saying no service. it may have one dot for maybe 5 seconds when turning flight mode on/off or when I reboot the device, but after 10 seconds or so it says no service. In cellular settings I can confirm it is the right network, and it reads the sim. I get asked for the pin code when putting it in.
I have also tried another SIM card in my device and its still the same issue. I tried using my sim on my older phone, and it works in that device.
So i’m guessing it is a hardware issue or something like that. Please help! Thanks in advance.
Score 3
Add a comment
Since it is asking for a sim pin, the device is “locked” (not actually, but functionally) from your network. If you have Sprint (or I guess TMobile now) your sim needs to be “activated” for that device on their end.
You can do this from the website in many cases as long as you can provide the imei number and the number from the SIM card.
Add a comment
Have the same issue here on my recently purchased 11. No carrier lock on the phone but it only accepts one network (Cell C) other sims register but show no service with symptoms listed above. IMEI has not been blacklisted. Can anyone help?
Add a comment
I have the same problem, i need help to
Add a comment
I will try to replace the SIM reader and I will send to you the feedback.
Add a comment
Şebekede sorun yaşıyorum yüksek internet gerektiren uygulamalarda çok fazla gecikme ve ping yaşıyor kullanamıyorum aynı sim kartı ve aynı telefona sahip herkes kullababiliyorken ben kullanamıyorum.
Add a comment
Add your answer
Mathias Fadnes will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 7
Past 30 Days: 36
All Time: 960
