Up to 20% off select tools
Soldering is a method of connecting two pieces of metal together by melting another filler metal in between them. There are many kinds of soldering, but this article is designed to teach you the basics of electrical soldering.
Smart Watch back panel
does any one know how to attach the back cover of a fossil explorist gen 3. the back panel came off, and 2 wires are visible. ive got no cl
ue where to re solder them to.
Score 1
Add a comment
1 Answer
Chosen Solution
Really late but might help someone.
Use a case opener and unscrew the back. If you look at the pic the wires solder to the connections hidden under the back to the left. Under magnification you’ll see where they were solder too. Long wire to the left and short wire to the right. If you are unsure where to find the connections look for ‘witness marks’ on the joints.
Score 1
Add a comment
Add your answer
saevhan mohammed will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 7
Past 30 Days: 26
All Time: 513
