Up to 20% off select tools
A more affordable, purely handheld version of the Nintendo Switch game console, with integrated Joy-Con controllers and a slightly smaller screen. Released September 20, 2019.
Thermal compound / paste replacement
So I have a switch lite that i completely dissasembled for a housing replacement and I found out that theres two types of thermal stuff inside (thermal putty? and regular thermal paste). I have MX-2 thermal paste but im not sure if i can replace the pink stuff with it. Is is possible?
Score 2
6 Comments:
ah yes the wad of pink chewing gum
by Share
@seizure_salad looks kinda tasty, i honestly wanted to try it
by Share
Where is the thermal putty applied?
by Share
between the metal shield and heatsink
by Share
After removing the metal shield clean the old puddy out and reapply between the heat sink and shield and the lower part of the switch.
by Share
Show 1 more comment
Add a comment
1 Answer
Yes that should work fine make sure you clean the old thermal paste off and reapply.
Just make sure its non conducive.
I use artic
Add a comment
Add your answer
Vladimir Avramovic will be eternally grateful.
Past 24 Hours: 3
Past 7 Days: 8
Past 30 Days: 46
All Time: 1,893
