Repair guides and support for the third generation Dodge Dakota (2005-2011). The redesigned 2005 Dakota shared its platform with the new Dodge Durango SUV (which is now similar to the Ram platform).
Replacing trans cooler lines
2005 Dakota, 3.7, I have trans cooler lines disconnected from trans and cooler but cannot snake them out between frame, engine and trans. Can somebody tell me what needs to be removed, lifted, etc to make room for removal of trans lines?
Thank you in advance for your support!
Add a comment
You will probably have to unbolt the engine mounts and lift up on it. There are no instructions for this. You will just have to work them through. Leave the transmission mount connected when you disconnect the engine mounts. And first thing is disconnect the battery. No chance shorting anything
Add a comment
bend/break the old line. and slide in the new one.
Add a comment
Add your answer
Wesley will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 5
Past 30 Days: 24
All Time: 2,480
