Released October 26, 2018. Models A1984, A2105, A2106, A2108. Available as GSM or CDMA / eSIM, nano-SIM or dual-SIM / 64, 128, or 256 GB / Black, White, Blue, Yellow, Coral, or Red. (Pronounced "iPhone 10 R.")
Which microphone is broken?
Hi, My iPhone XR microphone doesn’t work on speaker calls but works fine on normal calls.
The strange thing is that Siri works fine, (which uses the earpiece mic),… and normal phone calls work fine which i believe uses the bottom mic.
Voice memos just records static, same as speaker calls for people on the other end listening.
Front facing and Rear facing video all record sound fine..What should i be replacing here?
Score 5
Add a comment
1 Answer
Chosen Solution
The connector microphones are located on the charging port assembly. One of these microphones has become faulty. I am not sure which one handles the voice memo and speaker phone. Replace the charging port assembly and the audio should be fine.
Score 3
2 Comments:
Thanks for the quick reply Chris!, ill gave that a go and report back. I had no idea the bottom had multiple mics!
by
Hello please any update
I’m having the same issue
If you fixed the issue how did you do it?
by
Add a comment
Add your answer
s_joseph_ will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 9
Past 30 Days: 23
All Time: 6,103
