Released in May 2018, this is a mid-range phone with a 5.6" screen and a 3000mAh battery.
Why is my phone not charging?
A while ago my phone started charging slowly after i forgot it in the bathroom and i took a shower. I think a little bit of water got inside directly and more through water vapors.
I didn’t think much about it because the phone still worked fine. But after some time it started charging slowly (using all box charging equipment), i was using ampme and saw that it was charging with only a small portion of the power it was supposed to.
I didn’t do anything about it since i was a bit scared and hopeful that it was a passing thing, and than it became so bad that i let it charge overnight and it would charge only 10% and now it stopped charging at all after the battery got drained .
What part of the phone might be damaged ?
Add a comment
Most Helpful Answer
i would try a different cable first, if that doesnt solve the issue then have the charge port replaced with a genuine replacement
Score 1
Add a comment
My phone is charge very slow and falls battery very fast.I am very upset ftom this problem
Add a comment
Add your answer
nagitcgabi will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 2
Past 30 Days: 21
All Time: 547
