Up to 20% off select tools
1.83 GHz Core Duo or 1.83, 2, or 2.16 GHz Core 2 Duo A1208 (EMC 2104/2110/2114/2124)
Blinking a file with question mark
When I plug in and turn on the computer there is a question mark with a file inside of it blinking
1 Comment
Hi @amanda0881
Sounds like it is not able to boot / find OS files.
Does it happened suddenly after some time of usage?
There is a probability that could be due to faulty hard disk inside.
by Share
Add a comment
1 Answer
Most Helpful Answer
Do you still have the grey disks that came with the system? If you do you should find one that lists diagnostics. Insert it and boot your system. Did it boot up? Are you able to run diagnostics?
Score 1
Add a comment
Add your answer
Amanda will be eternally grateful.
Past 24 Hours: 4
Past 7 Days: 6
Past 30 Days: 16
All Time: 295
