Up to 20% off select tools
Quadcopter drone manufactured by GoPro for aerial videography.
Main Board Chip replacement
Hello. I bought this Karma with everything for 150. However, I bought it broken. I located some broken chips. I am good and replacing chips, capacitors, resistors on boards, but I am terrible at the moment knowing what any of it means.
I supplied pictures, could you guys/gals let me know what these are and where I can buy them to reflow them onto the board???
https://ibb.co/BsFMDVp
https://ibb.co/dDgKNSN
https://ibb.co/bKj8J3W
https://ibb.co/7GDbcK2
https://ibb.co/f46wx3y
Add a comment
you would be better off just buying another one with the pairing issue cheap. The pairing issue fix has a very high success rate. That board could have other issues that you cant see.
Add a comment
Img #1 is a 15µH inductor
Img #2 is a 100µF 35V SMD electrolytic capacitor
Img #3 unable to determine if this is a bad connector or bad ribbon cable
Img #5 is a BSC0588- N-CHANNEL POWER MOSFET
Add a comment
Add your answer
rookerdesigns84 will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 1
Past 30 Days: 29
All Time: 313
