Guides and repair information for KitchenAid mixers.
Carbon brush stuck in machine
My kitchen aid stand mixer wont turn on. I watched a video and it said that the carbon brushes could be old. My mixer is 1 year old so i said screw it and ill take a look. Turns out the spring was not even on the carbon piece and now i cannot get the carbon brush out of the machine. I dont have tweezers small enough to pull this out and apply the spring to see if this was the problem. Is there any way to help out?
Add a comment
You are probably not going to like thus answer. The machine has to be disassembled to push the brush out from inside. The following Service Manual will cover disassembly and checking the speed adjustment after re-assembly.
Make sure that the chamfered side of the brush is in the correct position.
++http://www.kitchenaidparts.eu/documents/...
Add a comment
Hi,
I had the same problem and thought I would have to take apart the whole thing.
I started to, but when I tried to remove the pin from the planetary (you have to use a hammer), the impact alone made the brush go out by itself!
1 Comment:
What about superglue or 5 minute epoxy on the of a chop stick or bamboo squewer? Wouldn't that be easier & quickir than dissassembly & Reassembly??? Going to do it tomorrow after I buy those two "tools". !!!!!
by
Add a comment
Heya,
Had the same issue. I ended up taking a small screwdriver and just ever so gently nudging the carbon brush loose and then tilted the standmixer to smack it out by tapping on the opposite side.
Now my Artisan runs like new (which it just so happened to be as well…)
2 Comments:
FYI, make sure the standmixer is NOT plugged in to any outlet of course! :)
by
yes fixed mine your way as well thanks for explaining!
by
Add a comment
I have an old 5-quart pro model (model number KSM5PSWW). I had to disassemble the machine and was having trouble figuring out how I'd remove the armature when I realized that I could bend a paperclip and use that to push a broken brush out of its hole. I got it out far enough out to grab gently with a pair of needle-nose pliers. It was a bit of trial-and-error to figure out the correct rotation of the brush, but I got there.
The machine is working properly now.
Add a comment
Add your answer
hendres3131 will be eternally grateful.
Past 24 Hours: 6
Past 7 Days: 18
Past 30 Days: 59
All Time: 3,493
