Up to 20% off select tools
The HP Envy 4520 is an all-in-one wireless printer and scanner that was manufactured by Hewlett Packard (HP). It was released August 2015 and can be identified by the product number F0V69A#B1H.
Clearing a paper jam
I can’t get hold of enough paper to slowly pull it out. The jam is at the front small roller, not under the paper path drawer. Paper has rolled around the front roller several times and there is about 1/4” of paper sticking out, not enough to pull
Score 1
Add a comment
1 Answer
Chosen Solution
Open the top copier door and glass door at the same time, like you're changing the ink. At the very back, there is a flap with 2 gray slide pulls that you pull toward each other, then pull upward. Your stuck paper debris should be there, clear it out. Hold the 2 slide pulls again and put the flap back where it was. Close lids and the menu should ask if it can continue.
Score 1
Add a comment
Add your answer
Connie Staats will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 7
Past 30 Days: 26
All Time: 1,016
