Up to 20% off select tools
The Epson Stylus NX415 is a color inkjet printer. The printer uses T088/69/68 ink cartridges, which use a wetness sensor behind the visible primary chip.
Error message displayed on printer.
The following error message is displayed on the printer. “ a printer error has occured. Then off the prjnter, then press On button to turn on. See your documentation. “ When this is done the error message is still there, even after unplugging the power and the line to the
2 Comments:
Please tell us the full error message and code if it had one.
by Share
It just says error turn off and then on. It didn’t do anything
by Share
Add a comment
1 Answer
  1. Turn off the printer using the Power button.
  2. Use a pin to press and hold the Reset button at the back of the printer.
  3. Turn on the printer but keep the Reset button pressed for at least 5 seconds.
  4. Release the Reset button after a warning page is printed. After a few seconds, another page with the default IP address of the printer will be printed.
  5. Use this IP address to reconfigure the printer to the computer system.
Add a comment
Add your answer
Robert Passanisi will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 11
Past 30 Days: 43
All Time: 355
