Guides for the LTE version of the iPad Mini 2. Announced October 22nd and released November 12th, 2013. The iPad mini 2, originally known as the iPad mini with Retina Display, has all the pixels of the iPad Air in a smaller 7.9" form factor.
Replaced my screen digitizer.
I replaced my digitizer and anytime I press on the screen, I can see the LCD liquid getting squished even with the lightest taps. I made sure that there is nothing in the way under the LCD which is all clear. Why does this happen?
Add a comment
1 Answer
Chosen Solution
Usually it comes to one or more of the following:
  • The 4 screws that hold the display down at the corners are not put in.
  • The battery has started to expand putting pressure behind the screen.
  • The housing of the iPad is bent in a way that does not let the digitizer sit flat without touching the screen.
  • Also there is usually a protective film that needs to be peeled off behind the digitizer which can also cause this problem as it adds thickness to the screen.
Score 1
Add a comment
Add your answer
Imatrueguy will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 4
Past 30 Days: 10
All Time: 168
