This iteration of Amazon's Kindle Paperwhite series was released on June 30, 2015. The Kindle Paperwhite 3rd Generation is a 6-inch, 300 PPI reading display tablet that is Wi-Fi capable. The designated model number is DP75SDI.
Kindle Replacing USB socket by bypass inside
Hi,
I started replacing the USB socket in my Kindle but accidentally the conductor strips were thorn.
Now, I want to do a bypass and solder it directly to the right spot using thin wires.
The problem is that I can't determine where to solder them.
Could you advice me where to solder all 4 pins?
Thank you,
Erez
Add a comment
Chosen Solution
You see the light coloured lines that lead to where the pads were. Scrape them until you see the copper trace then solder from there.
Score 1
Add a comment
Old post lol. Clean the board and follow the traces. Might help someone else with a similar issue.
Score 1
Add a comment
Add your answer
Erez Lahav will be eternally grateful.
Past 24 Hours: 2
Past 7 Days: 10
Past 30 Days: 33
All Time: 535
