Up to 20% off select tools
A smartphone by LG released November 2012.
Restoring data from a dead phone?
I’ve looked online a bunch but none of the things I found helped.. The phone has been dead for years, found it recently during cleaning. I know there are a ton of memories on it. Also, I THINK the phone model is correct.. it’s been years, but I’m 85% sure the one on the picture is identical.
When i plug the phone into my PC, it is detected.. but not recognised. Does a nonstop loop of connect noise-disconnect noise-device not recognised notification. Cannot turn it on at all, not even a screen lit up. Any ideas?
Add a comment
1 Answer
Hi
Try replacing the battery -example only and see if the new battery will start to charge.
If it does start charging, allow it to charge >80% before attempting to turn on the phone.
It may be that the depleted/dead battery is causing problems with the power needed to start the phone i.e. trying to charge a dead battery and turn on a phone at the same time.
It’s a small enough gamble
1 Comment:
I'm afraid this is beyond battery issue.. The phone used to work on cable charge alone, without any battery.
by Share
Add a comment
Add your answer
f.karvay will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 3
Past 30 Days: 19
All Time: 332
