Repair guides, disassembly, and troubleshooting information for the second-generation Apple iPad with Wi-Fi, available with 16, 32, or 64 GB of storage. Released in March 2011. Identified by model number A1395 and EMC 2415. Repairs require the use of heat and careful prying.
digitizer ribbon cable ZIF sockets
Hi guys, I´ve followed your steps to change the ipad front panel but I messed up the “digitizer ribbon cable ZIF sockets” trying to “prying up on the hinged retaining flaps” Can I buy just that part? the front panel its perfect but i miss-understood the steps and broke those connectors…. Did I need a new complete logic board? thanks a lot!
Add a comment
1 Answer
Chosen Solution
Replacing those connectors requires some micro-soldering so unless you have experience doing this kind of work, it is not really a DIY repair.
A repair shop that specializes in micro-soldering repair should be able to do this for you. Depending on where you are located, you’ll need to consider if it is a worthwhile investment for such an older device. Alternatively, you may be able to find a used logic board for less than the cost of the repair.
Score 3
1 Comment:
Thanks a lot!
by
Add a comment
Add your answer
joao will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 26
All Time: 328
