Repair guides and support for the 5th generation Honda Civic, first released in late 1991.
Radiator fan not turning on?
Hey guys I think I have a more complex problem or I have over analyzed my situation with my 1992 Honda Civic 4 Cylinders 1.5L MFI SOHC
Car Overheats after about 5 to 10 minutes of driving. Radiator fan never engages to turn on, I also noticed it takes the coolant but the radiator fan still does not turn on. Checked the fan switch by bridging the current and fan turns on.
I replaced following:
cooling fan relay
temp sensor
fan switch
thermstat
I checked the other fuses underneath the hood and they were all good. Not really sure where to go from here. What are your thoughts
Score 1
3 Comments:
Alejandro Garcia hat is the exact year, engine size and model for your Civic? That way we can chase the wiring and hopefully get you a good answer.
by
1992 Honda Civic 4 Cylinders 1.5L MFI SOHC @oldturkey03
by
Add a comment
1 Answer
check the pigtail on the thermo Switch next to the to the Thermostat housing for loose wires
Add a comment
Add your answer
Alejandro Garcia will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 2
Past 30 Days: 25
All Time: 917
