Apple's operating system for its Mac desktop and portable computers.
Trying to install El Capitan on iMac
My MacBook is running Mojave and I need to instal El Capitan on my iMac (what was on it before I needed to replace a bad hard drive).
I can’t get it to download using my MacBook through legitimate Apple sources.
HELP! That link Aaron provided is from Apple and since I am running Mojave I can’t download it.
Score 1
3 Comments:
So if anyone had this same problem and could help me before I pull ALL of my hair out that would be greatly appreciated!
by
Same here, any luck?
by
did you get to the bottom of this? im in exactly the same situation
by
Add a comment
1 Answer
Depending on the age of your iMac you should be able to install your new SSD into your system and then run the Internet restore using the start up keys: Command (⌘) & R keys
Reference: About macOS Recovery
To gain access to the older macOS’s use the startup keys Shift & Option-⌘ & R keys
Reference: Reinstall from macOS Recovery
Add a comment
Add your answer
amanda819 will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 8
Past 30 Days: 27
All Time: 920
