Up to 20% off select tools
The Nintendo GameCube Controller DOL-003. Released November 2001, compatible with Nintendo GameCube and the Nintendo Wii, and to a more limited extent, the Nintendo Wii U and Nintendo Switch. Repair for this device is straightforward and requires only common tools.
gamecube controller drifting when I move left
I noticed that when I play super smash bros ultimate, even when i push my control stick to the right, my character goes to the left. I think it is a drifting issue, can anyone help me with this issue?
Add a comment
1 Answer
I had a Wavebird that was having the same issue. You need to replace the stickbox. You can order an aftermarket stickbox from Amazon or Aliexpress. What I prefer to do is to get a Wii Nunchuk with a good stick and desolder the stickbox. The Nunchuk and Gamecube controller use the exact same stickbox so you can simply solder it onto your Gamecube controller.
2 Comments:
Was is the stickbox? Do I need a screwdriver to get the stickbox out?
by Share
The stickbox is what actually reads your stick movements. To replace it you'll need a Tri-Wing screwdriver and a soldering iron. Here's a tutorial. https://www.youtube.com/watch?v=KpZFeJU9...
by Share
Add a comment
Add your answer
Pokemonman You will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 4
Past 30 Days: 35
All Time: 4,101
