Repair guides, disassembly, and troubleshooting information for the 5th-generation Apple iPad with 4G LTE, available with 32 or 128 GB of storage. Released in March 2017. Identified by model number A1823. Features a 9.7" Retina display and 64-bit A9 processor.
Digitizer Ghost touching after replacing digitizer
i recently replaced my ipad 5 LTE digitizer and it was working fine after the repair but the home button was loose so i figured ill put some glue on the piece that holds it in place and it’ll stick. It fixed my issue but now i have a lot of “ghost touch” on the display.
Add a comment
1 Answer
Check that there isn’t any pressure applied to the screen around where it’s ghosting. If you had to remove the display to fix the home button issue, you could’ve damaged the digitizer flex cable.
Add a comment
Add your answer
Kamil Malec will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 17
All Time: 330
