Released in April 2019. Model Number: A705FN/DS
Black Screen after it fell
MySamsung Galaxy A70 has a black screen the phone works I can hear it when someone calls or when I restart it but the screen is black any help full suggestions
Score 7
7 Comments
Yes I can hear alarm sound
by
All r working well but in a corner black and parpel sport in the screen
by
It’s makes a little sound when I charge it but it won’t turn on what can I do pls someone help me
by
@Adam Lasri anything happened to it? what have you checked?
by
@oldturkey03 it fell then the screen went black but you can hear it and everything so what dose it mean
by
Show 2 more comments
Add a comment
Most Helpful Answer
Ik this is from a while ago but just in case anyone else is having this problem, i had this exact problem but when doing a soft reboot the screen became white and pixelated, like an old school tv. I massaged the back of the phone and that seemed to reconnect whatever wire came loose and made the screen work again.
Score 4
3 Comments:
Thanks dude, this massaging trick fixed it for me :)
by
I thought I would’ve had to spend a couple bucks to save this thanks for this trick
by
Whoever posted this has saved me lots of $s. My phone fell and went blank as well. I could hear messages coming in so I knew it worked. I came here for a solution and tried this trick. Took, literally less than 10 secs of massaging the back and screen came back to life. Thank you so much.
by
Add a comment
Zweber Steyn  since this happened after your phone fell and you already tried a restart, it stands to reason that this is a broken display. Of course, you always want to check for loose cables etc. but be prepared that this may need a new display. Here is how to do it and displays are available at places like this and many more.
Add a comment
i actually got this problem and knew it was a loose cable because my screen was replced so i opened it and found only 2 screws the other were stolen so i disconnected the battery grabbed flat surface screw driver and placed it between the plast layer cover already removed then i clicked on the battery to lower card and it got plugged in and now my screen works just fine.
Add a comment
Add your answer
Zweber Steyn will be eternally grateful.
Past 24 Hours: 2
Past 7 Days: 7
Past 30 Days: 35
All Time: 13,856
