Larger version of the Nintendo DSi, released March 2010 in North America. Most repairs are accomplished with only a screwdriver and prying tools.
Top screen has lines and is faded
My XL was dropped and now the top screen is really faded and has lines on half the screen. Bottom screen works fine and sound does too. Only problem is the top screen. Took it apart but what do I need to look out for?
Thanks
Michelle
Score 1
Add a comment
Most Helpful Answer
Here is the Guide and the part is available here and many other places As for hard to replace, it does depend on your skills and comfort level.
Replace a damaged or malfunctioning 4.2" 256 x 192 Upper LCD panel compatible with the Nintendo DSi XL portable gaming console. Image
Product
Nintendo DSi XL Upper LCD
$84.99
Score 2
Add a comment
You cannot really fix this problem, the only thing that you can do is replace the top screen. If it was dropped the screen was probably smashed (inside LCD) and there is nothing you can do other than replace it.
Sorry for the inconvenience.
1 Comment:
Would it be hard to replace? And would it be cheaper to send it Nintendo to fix? They charge me $80 to fix.
by
Add a comment
The top LCD is not a great DIY project unless you're used to handling small ribbon cables. If you aren't careful, you'll tear the new ribbon as you're installing it. New LCDs are $10-$20 on ebay. Good luck.
Add a comment
i have the same problem!!!!! don't want to send on it in or replace
2 Comments:
jala mcfadden, what problem do you have with your DSi and what did you try to fix it?
by
jala the only place you can put your contact information id in your profile.
by
Add a comment
Yeah one day i decided i wanted to play on my Dsi XL and I struggled to pick it up from my desk and when i finally got it i opened it and the top screen was like halfway blacked out and random color lines were on it too i have know idea how to fix it plus its not even mine
Add a comment
have heard that the ribbons can be replaced but it needs specialized equipment like Z axis tape (this is for the lines only/blank problem, and a subset of those) but the glass is normally the cause.
I have a very expensive camera here with this fault, internal cable went bad but its a special sort of tape more expensive than standard Z axis as used in ipad repairs, chibitronics kits etc.
This works fine if the alignment is spot on for relatively large pitch connectors however like calculator panels!
If you have a good ribbon and screen then try https://www.adafruit.com/product/1656 might do the trick but alignment needs to be finer than a human hair.
Best done under a microscope or better still screen+camera.
Add a comment
Add your answer
Michelle will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 13
Past 30 Days: 72
All Time: 9,284
