The ASUS X751L is a large screen (17.3 inch) fourth generation i3 dual core laptop released in 2015. Identified by model number X751LX-DH71.
Can I install a touch screen into this system
broken screen on my asus i found a touchscreen same size different pin question i have is will the current mother board support touch? can i flash bios or something to enable touch. some1 please guide me in the propper direction ty
Add a comment
1 Answer
Most Helpful Answer
@petercw Anything is possible so you can always try but we can’t answer that unless we see what board (connectors etc.,) you have.
Score 1
3 Comments:
ty i will post it when i get home i currently use the system in my living room conected to tv. do i have to open up the case off or is it in system info or in bios maybe?
by
Th eboard number may be in the system info. Most commonly would be that it is not compatible since the hardware requirements are different.
by
the mb is a X751LAB i dont really care if the touch works at this point but under system settings it says touch not enabled
by
Add a comment
Add your answer
Peter W will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 5
Past 30 Days: 22
All Time: 295
