The March 2019 refresh of Apple's iPad Mini tablet, featuring an A12 Bionic SoC and an updated True Tone Retina display with Pencil support. Available in Wi-Fi and LTE with 64 and 256 GB storage options.
Delay in start charging ipad
Recently I bought an iPad mini 5, it works perfectly fine and keep battery very well but when I want to charge it when I plug it into the charger it sometimes take a few seconds (like 4-8 seconds) to start charging and I have to mention that I use Ipad’s original charger and cable and I also used anker power bank also my iPhone charge but I still have this problem.
Any one has experienced it? and anyone knows is it serious problem and is it may damage my iPad?
Score 2
Add a comment
Most Helpful Answer
Exact same issue here on the iPad Pro 2020: can vary between 10 seconds to over a minute! And that’s with the official USB-C charging cable and fast-charge plug that came with the device
Curiously, using an old iPhone adaptor and USB to USB-C starts charging the same device immediately
And likewise: the official cable and charger are recognised immediately if the unit is powered off
Bizarre, very basic, issue
Score 1
Add a comment
I also have this problem, I think it’s an issue in iOS/PadOS as I’ve seen iPhones also do this is some versions of iOS.
Add a comment
I am currently going through this issue. I have tested on Apple branded and other brands of charging wires and ports but issue remains. I’ve contacted Apple and I got my replacement today. Issue is also on the replacement.
1 Comment:
Maybe its an issue with many ipad minis, mine does the same
by
Add a comment
My new ipad mini is always have this same issue :( whats wrong :( do you think this is an ios problem?
Add a comment
My Ipad mini 5 also has the same problem. Everything is perfectly fine but still it is anoying
Add a comment
Mine also does the same sometimes it takes 15 seconds, no delays when it’s powered off though
Add a comment
You should turn off your device before start charging..
Add a comment
Add your answer
navid arbab will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 20
All Time: 2,587
