The PlayStation 3 (or commonly known as the PS3) is the third home computer entertainment system produced by Sony Computer Entertainment, and the successor to the PlayStation 2. It was released November 11, 2006
PS3: extremely noisy fan
As soon as the console starts up the fan is blowing hard.
The noise is not scratchy or anything but the fan spins at full speed. The console does not seem to be that hot to justify such a blowing.
Can anybody help?
Thank you
Armando
Score 9
10 Comments
Armando which PS3 do you have? Does it have enough airflow? Are the airvents clear of any obstruction? How hot is the room where your PS3 is located? Do you have it on the floor or in a cabinet?
by
It's the standard PS3 (not the slim version). Airvents are clear, the room is not particularly hot, even in this summer days the room is somewhere in the neighbor of 24-25°C, and the console is on the floor in a vertical position.
by
I'm sure there is guide on here for how to keep your console (xbox/ps3) in best ventilation and maintenance to prevent ylod etc which might be of use..i think it mentions not vertical?
by
I think the 40 GB has a "Fan Test" feature. Switch off console on front, so red lights appear. Place your finger on eject button (keep it held on), switch it off at the bak with your finger still on eject button, then switch it back on. I believe that this will run the fan at its highest speed to "blow out" any debris. you might want to give it a try.
by
It could be that the thermal paste on the heat sink has dried out and it needs to be applied again . I had a computer that was doing that so I took the heat sink off off the CPU on the motherboard and reapplied the thermal past now it's very quiet. Since consoles these days are like computers that could be it
by
Show 5 more comments
Add a comment
Chosen Solution
slim guide:PlayStation 3 Slim Fan Replacement
normal guide:PlayStation 3 Fan Replacement
slimline guide:not available
normal(ps2)guidePlayStation 2 Fan Replacement:
PlayStation 2 Fan Image
Guide
Difficulty:
Moderate
40 minutes - 1 hour
PlayStation 3 Slim Fan Image
Guide
Difficulty:
Moderate
15 - 30 minutes
PlayStation 3 Fan Image
Guide
Difficulty:
Moderate
30 minutes - 1 hour
3 Comments:
the problem is the fan doesn't like the changes of the console and will blow hard for for a warning and/or the fan may not be properly seated,so these guides are the solution (sorry there's no ps2 slimline fan installation guide)
by
It is now clarified that the device in question is a PS3 non-slim version. So you can clean your answer by deleted the unnecessary links.
by
Add a comment
Most Helpful Answer
The ps3 fan has 3 fan speeds (factory standards)
In summer its humid hot etc the air blowing out might not be HOT but the components inside are so this is what its cooling down!
You can notice the fan is louder when it goes at full speed but this is normal
3RD party fans DO NOTHING IN THE SLIGHTEST!
Get AIR CON
Or get a small fan blowing air onto the console. And make sure it isn't clogged up with dust.
Score 4
Add a comment
Sit your PS3 up on something to let the bottom ventilate. Instead of standing it up, lay it down and prop it up on a couple of tuna cans or something...anything to get it up off a surface. That should help quiet it down some.
Score 1
Add a comment
Take it apart and clean it with air compressor. I just cleaned mine due to loud fan, now it's quiet as can be!
Score 1
2 Comments:
Hi, can you give me idea of what you mean when taking apart and cleaning system? Also, what compressed air do you use on it?
by
Add a comment
Usually it sounds loud because it is overheating dust is clogging it so the fans are to cool them I recommend that put some cool air conditionar near it and put it above the floor with something soft.
Score 1
Add a comment
I encountered the somewhat same problem with my ps3 only after 10 to 20 minutes of operating time the fan would go into high blow mode sounding like a jet engine. Proceeded to feel the air at the back of console and the temperature was very warm. I then unplugged all cords and used compressed air from my air compressor with 2/16 inch rubber nozzle on air gun and began flushing all dust from every angle and every open port including taking off the sanp hard drive door also. Continued flushing with compressed air for about 10 to 15 minutes until no more dust debris came out. Plugged all cords in and turned on waited for the fan to kick into high and didn't also temperature of air coming from the back of console seemed alot cooler also. Sidenote using compressed air in can might damage componets by coating essential components with frozen nitrogen hindering porcesses and doing permanent damage.
1 Comment:
I just used your Technic and it worked so %#*@ good that I didn't know my shyt came on! Quiet as a Mutha!
Thank you
by
Add a comment
Honestly a major factor in fan noise is the position of the console to the surrounding material. So if the PS3 case touches a solid surface, it will sound much louder. If the PS3 is near a wall or solid surface, it will reflect sound waves more efficiently and make your PS3 fan much louder!
You can dampen the noise by moving it away from solid surface and raising the console a few inches on something soft (paperback).
Add a comment
After reading all the posts and knowing that my fan is not faulty it's just running full speed, I realized I have never blown the dust out of it. I turned it on and my fan ran for a few seconds and immediately goes full speed for about 3 seconds and then calms down. I unplugged it took it down to the shop and blew it out with my air compressor at all different angles in every whole back and forth and even when one side seemed clean I blew the other side out and realized it was blowing dust back and forth inside you must go back and forth between all of the ports many times until no dust comes out. If your fan is not faulty it is obviously a heat problem especially on systems like mine which is the 80 gig first generation with almost full backwards compatibility with PS1 and 2. This unit was the first of its kind and I had to special-order it. The later units had the backwards compatibility removed and some processor load reduced in order to lower power consumption. This is very common on the first generation. I would not suggest taking your PS3 apart if you ever plan to have it fixed by Sony they will not touch it even if you pay them. No one has ever opened my system except Sony for a hard drive replacement many years ago. I agree not to use canned air because if any liquid comes out of the can if it does not damage the board it could cause the heat sink paste to become brittle and not conduct heat away from the processor and the fan will always run fast. Blowing the unit out has made a huge Improvement but be careful and do not blow air near the disk slot or you can get dust on the laser and your Blu-ray will not work correctly and don't hold the air hose directly on the vent holes give it 5 or 6 inches in case there is some water condensation in your airline I suggest using an airline with a dryer on it. This has fixed my problem. I have done some temperature test and this unit does run cooler if laid flat because then there are no vents on the bottom. This unit is going to be louder than the later version because it is a power monster. Also suggest you hang on to this unit they are getting rare if you have one like mine with the door and all the slots and 80 gig hard drive and full backwards compatibility. I was offered more for mine than I paid for it which is very rare for a game console so take care of it. Hope this helps.
1 Comment:
take your system completly apart, wipe off the crusty thermal paste on the apu and slop new thermal grease all over the top then put it back together as best you can. left over screws are normal just throw them out
by
Add a comment
Add your answer
Armando will be eternally grateful.
Past 24 Hours: 4
Past 7 Days: 39
Past 30 Days: 199
All Time: 217,871
