The De'Longhi EC155 is a Pump Espresso and Cappuccino maker.
Cleaning the boiler outlet
I can’t get the screw out to clean the boiler outlet. It seems to be welded in. Water won’t pump through. Do I have to throw the whole machine away because the screw won’t come out?
Update (01/08/2020)
Here are the pictures of the screw I can’t get out and the boiler holder (holds the coffee filter).
Score 2
2 Comments
jwsacco post some good pictures of what you are up against. That way we can see what you see and hopefully help you out.Adding images to an existing question
by
I can't get the screw out. It's stuck fast. I have tried WD40. Any advice would be appreciated.
by
Add a comment
1 Answer
Most Helpful Answer
jwsacco it is not welded in. I think it is just hard to get a good grip on it. Use a phillips head socket and a ratchet. Place the socket into the screwhead and use a small hammer to tap the bottom of the socket thus loosening the screw a bit. The use the ratchet on the socket to remove the screw.
Check the first 45 sec off this video
Score 1
Add a comment
Add your answer
jwsacco will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 15
Past 30 Days: 61
All Time: 3,259
