Sd card not working or reconizing
I just fell my phone on road and a car went from above it and now my sd card is not working or reconizing on pc and phone..can anyone help me..
When connected through USB, your SD card may not be detected by your PC for a number of reasons:
Your SD card can be defective or damaged, which would make it impossible for your PC to recognize it. Check a different SD card to determine if the issue still exists.
Connection problems: Verify that the USB cord is functioning properly and that your phone and PC are properly connected. To see if the issue is fixed, try an alternative USB cable.
Driver problems: The SD card may not be identified if your PC does not have the required drivers installed for it to recognize your phone. Attempt to obtain and install the most recent drivers for your phone from the maker's website.
Incorrect settings: Check the settings on your phone to ensure that it is set to transfer files and that the SD card is not being used as internal storage.
Outdated software: Make sure that both your phone and PC have the latest software updates installed, as outdated software can cause compatibility issues.
If none of the above solutions work, it may be helpful to consult with a professional or contact the manufacturer for further assistance.
Past 24 Hours: 0
Past 7 Days: 6
Past 30 Days: 24
All Time: 329
Can you see any physical damage to the card or the slot for it?
by mike
No. No physical damage can be seen
by Ahmed Shahid
Have you tried something like Recuva on your PC to recover the photos and files?
https://www.majorgeeks.com/files/details...
Then reformat the card on your PC.
The card may have just gotten
by mike
No i haven't try any application because my pc is not reconizing my sd card
by Ahmed Shahid
So it does not even show up in Disk Management?
Video to show how to get to Disk management:
https://www.youtube.com/watch?v=zVWExJ8w...
If none of this works then I guess the SD card is unfixable.
by mike
Show 2 more comments
