The Corsair Void Pro RGB is an optimal wireless headphone compatible with most media devices. This set features both dual speakers and a microphone.
Battery Replacement with 2 pin
I bought a li po battery with only 2 pins on it instead of 3. Can I still use this? Based on my research i can use a 10k fixed resistor. Anyone know how I can do that? Any help will be much appreciated.
Add a comment
1 Answer
Most Helpful Answer
Hi!
Yes you can probably get it working with a 2 pins battery, but I wouldn’t do it.
Just return the battery and get yourself the correct one that is supposed to work with your Corsair Void Pro RGB, it will spare you some trouble too.
Score 1
2 Comments:
Thank you for the input but your suggestion is not possible for me due to logistics on acquiring the battery
by
Okay. Do you have a picture of the battery you bought and a picture of the original battery ? Thanks in advance!
by
Add a comment
Add your answer
Merlin Meliodas will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 27
All Time: 440
